跳转到主内容
加入维修社区 - 创建账户
2017 年 6 月,Apple 更新了其 13 英寸 MacBook Air,配备了更新的 Broadwell Intel Core i5 处理器,性能和电池续航时间均略有提升。
A1466 emc 3178 no power symptoms
Reviving an old macbook air. no idea of previous status. symptoms- connect mag safe and indicator shows green then switches to solid amber, left an hour to charge, no response from power button. reset prom, cleaned everything and different power source same symptoms. question before I open it up, should it power up connected to mag safe even if battery is dead. looking for additional troubleshooting tips before cracking it open. any advice is greatly appreciated, thanks in advance. A1466 emc 3178
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
SMC might be latched, let's pop the bottom off and just disconnect the battery with nothing else connected. Follow this guide to Step 3 2017年早期MacBook Air 13寸 电池更换. Then press and hold the power button a good 15 secs to fully discharge the logic board this is a hard SMC reset. Now just plug in the MagSafe cord in the system should spontaneously startup. Did it or not? If it did let it fully boot up and do a clean shutdown.
Before reconnecting the battery is the battery blotted do you see any spillage or corrosion? Reconnect the battery and plug the charger in give it a try did it restart?
If the system is still dead after the SMC reset you likely have deeper issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spyder Photography 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 34
总计 432
