Why is my window wiper fluid warning light come on all the time
First thing I do is check for cracks in the tank and tubing. Thankfully, the window wiper fluid can't mix in the engine like radiator coolant can, so it's contained. Check for cracks in the tank, as well as damaged/loose/cracked tubing. It might be as simple as a new tank or a new piece of tubing. That said, if the tubing and tank appear to intact and there is no leak in sight, it might be a sensor issue.
This code will not appear on your typical OBD2 reader, as it is usually a vendor-proprietary B or C code - only the P codes are openly available due to emissions-related checks. Either buy an all-system scanner, or have it scanned and ask for a report and pay for ~1 hour of labor. Once you have the codes, you can start looking at it. But chances are it's a bad sensor. That said, without the exact year, we can't locate it, but search for "Nissan Armada wiper fluid sensor". If you have one in 2 separate places, I would change both IF both are less than $20 to make sure it's fixed for good. The Nissan P/N is 28911-1E400, and yours only has one sensor.
这个答案有帮助吗?
The year of the Nissan Armada is 2018 sv.
The year of the Nissan Armada is 2018 sv. Can you give me answer?
@davidmarti24727 The P/N is 28911-1E400 - take it to a Nissan dealer, or see if you can find a Nissan parts specialist. Don't buy some no name junk clone on Amazon.
@davidmarti24727 it is possible that you have a stuck or faulty washer fluid level sensor which would cause the warning light to stay on. The sensor is mounted in the bottom half on the side of the tank. It is a royal PITA to work on that since the sensor needs to be accessed from the right wheel well. Take a look at this video to see what is involved.
这个答案有帮助吗?
Good to know it's single sensor - then again, we didn't know the year so there was that guessing element. Hopefully the part isn't too pricey.
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 322
1条评论
why my window every time is open?
由 ᴀʀᴍᴀɴɢ ʀᴇᴋᴀɴɪ 完成的
