跳转到主内容
MacBook Pro doesn´t turn on but charges the battery
Hello
i have a Macbook Pro Mid 2009 13" and the problem is that it wont turn on. When i press the Power button nothing happens, its dead. But the battery charges and the LED on the left side shows the battery status.
Can you please help me?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Have you spilled anything on it?
No i didnt spill anything on it.
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
4个回答
已选择的解决方案
Your power button could be non functional. You could remove the bottom panel, disconnect the top case ribbon cable from the logic board then trigger the two power pads on the logic board to power up the machine. If the machine starts up then you know your top case is in trouble.
这个答案有帮助吗?
按维修分数 3
评论:
I'm assuming by top case ribbon, you mean the one on the top right after opening the bottom panel, with battery close to you. But where are the 2 per pads on the logic board to power up the machine?
Question, does this fix the button or merely turn on the macbook ?
添加一条评论
this might help
http://support.apple.com/kb/TS1367
这个答案有帮助吗?
按维修分数 2
评论:
Tried to reset but it didn't work. The light of the power cable didn't change.
What else can i try?
Move your Moniter in different angles while pressing the power button
It doesn't help because nothing happens when I press the power button, no fan noise, nothing
添加一条评论
try one of these solutions
http://youtu.be/Igspc4eymuQ
这个答案有帮助吗?
按维修分数 0
添加一条评论
I have a problem that my mac doesnt turn on and the battery shows the signe that ok and it charged normaly but when i press to turn on he make like when noise and exactly iheart it coming from the hitachi how you could help me please?
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Fuad 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 21
过去的30天: 86
总计 34,177
