跳转到主内容
加入维修社区 - 创建账户
Uses a smaller heatsink and a user-screwable stand.
Why won’t my disk go fully in the disk drive and why is it so loud
I recently replaced the laser on my disk drive and when testing I put a disk in and it made a lot of loud noises and the disk wouldn’t go all the way in. I don’t know what to do at this point and I would really appreciate the help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
There is something wrong with the mechanism of the disc drive!
Could be caused by the top part that takes disc’s in.
Is it possible to share some pictures with us regarding inside the disc drive?
Replacing the disc drive should solve it, but is more expensive.
这个答案有帮助吗?
得分 1
4条评论:
Uploaded need another?
完成的
The mechanism looks fine in the photo’s. You can replace only the top mechanism and see how that goes. Most easy way to test, is with another drive and see how that goes.
完成的
How would I get the top mechanism?
完成的
In your second photo, you see a black screw in every connor (4 in total). Take them out and you will can get the top cover off! Hopefully you can find the part online! Those are not easy to find..
完成的
添加一条评论
添加你的答案
Brayden M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 135
