跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解信息和故障排除信息,它是 DualShock 系列的继任者。可通过产品型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
Controller has two white lights under touch pad wont connect
It won't connect to ps5 will connect to pc Bluetooth but disconnects after 5 seconds and the lights stay on if I unplug the battery and pluge it back in they come back on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi!
The two white led's like that indicates that it's having issues to find the device to connect with.
Press and hold the PS button and Share button at the same time till the LED bar is blinking, then go to the bluetooth settings and connect to the controller.
If this isn't working, then try to reset the controller with the reset hole at the back.
Just to confirm, when you connect the controller trough USB, it works, right? If this is the case, then also update the controller it's firmware.
If all of above failed, then it's most likely motherboard related...
Please let us know how it goes!
这个答案有帮助吗?
得分 1
2条评论:
Yea tried it all nothing works bluetooth only works for a couple seconds on pc and it won't even connect to the ps5 well time to get a new one had that one since launch thanks for the help
完成的
Ah yes, then I'm afraid it's motherboard related :(. You can buy a new one or get it fixed with a new/used motherboard! If you buy a new one, I recommend to disassemble the controller and get the parts out which are working! Maybe it will come in handy if something happens with your new one! Take care and have a nice day!
完成的
添加一条评论
You're player 2
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kk Kk 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 89
总计 1,519
