跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
My controller does not charge even if I get a charger thats new
Every time I plug the micro USB into the controller, it does not charge. I got a brand new charger, and it still does not charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi! It does look like the battery is broken and need to be replaced. I would try this first and see how it goes!
If you need any guide, please let me know!
完成的
添加一条评论
1个答案
已选择的解决方案
olha provavelmente a tua placa de conexão ( que tem a entrada micro USB) deu problema no conector ... mas caso voce coloque o cabo e ele acenta ligue e tudo mais, o seu problema e bateria...
Translation:
Look, your connection board (which has the micro USB input) probably had a problem with the connector... but if you put the cable in and it turns on and everything, your problem is the battery...
这个答案有帮助吗?
得分 0
2条评论:
Ok thanks it probably is the USB port cause it looks like that thing in the center that goes into the micro USB is damaged
完成的
veja se a entrada esta folgada e coisa do tipo, ja peguei um que o probelma era somente oxidação no flat de conexao da porta para a placa, mesmo assim todos esses componentes são facilmente comprados na internet...
完成的
添加一条评论
添加你的答案
2knowndagoat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 105
