跳转到主内容
加入维修社区 - 创建账户
Broken hinge on Inspiron 7415 2-in-1
In what seems to me like regular usage, one of the screen hinges has broken off where it connects on the outside.
Any hints on how to repair this? If not replacing parts, at least getting it back together with some adhesive would be ok if there are diagrams of what it' supposed to look like.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @claytonhughes
Here's the service manual for the laptop.
Go to p.39 to view the procedure to remove the display assembly.
This will give you access to where the hinges are screwed onto the base.assembly.
If the hinge mounts are damaged you could try gluing the hinges down with a suitable metal/plastic adhesive otherwise you may have to replace the base.
The manual doesn't describe how to remove the LCD back cover so that you can check the hinge mounts there but here's a video that shows what to do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Clayton Hughes 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 70
总计 803
