My too speaker wire grounds then my stereo can’t power on how to fix.
Stereo speaker wire strip and rubbing together wild plugged, no power
Power on stereo
Get an AC power checker to check your homes outlets. And make sure the extension cords are also in good shape checking them as well. A $10 dollar unit is all you need like this one
This is a North American version, you may need a different one.
You may want to hire an electrician to fix your outlets and you may need to replace the grounding connection if is rotted out.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 101
If the speaker wires where shorted out then the Amp logic maybe damaged or just a fuse needs replacing. Best to find someone local who can help you.
由 DanJ 完成的
Hi @andremccurdy
What is the make and model number of the stereo system?
Which channel was the speaker wires connected to Left, Right, Surround etc?
由 jayeff 完成的
