跳转到主内容
加入维修社区 - 创建账户
广受欢迎的 Apple 迷你桌面电脑,2024款 Mac mini 的维修指南,拆解信息和疑难解答。该机型使用 M4 或 M4 Pro 处理器,最低配有 16GB 统一内存。
What tool kit I need need/buy for mac mini pro ssd 8T upgrade
I understand I need T3, T5 and T8 screw heads to remove all the screws in order to place 8T SSD card in a Mac Mini Pro 2025.
I understand TR8 means something else, not the same, but I can't find a tool kit that has all the screw heads I need. Any tips on which toolkit I should buy.
Many Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes it can be confusing! T is for Torx, TR is Torx with R for restricted (security), basically a variation of the screw that prevents access to the insides. There is a pin molded in the heads hollow preventing a normal Torx screwdriver from entering. A TR Screwdriver will fit both the normal and restricted versions of the screw.
The guide page offers a listing of the needed tools Mac mini (2024) and the Pro Tech Go Toolkit should be all you need.
Grab, Go, Fix! We created a bite-sized version of our best-selling Pro Tech® Toolkit, featuring the 32-bit Moray Driver Kit and our most essential repair tools.图片
产品
Pro Tech Go Toolkit
$49.95
这个答案有帮助吗?
得分 2
2条评论:
Many thanks Dan, for your prompt reply. I had a feeling the TR8 screw head unscrews T8 heads and yes it can be confusing. I'm amazed there are so many different screw heads, have no idea why. I would have thought the fewer, the better. Why can't companies standardise on fewer, not 30 versions.
完成的
@john88204 - There's lots of reasons we have so many screw types from the simple slot types to modern ones designed for robotic assembly (Torx)!
As well as engineers trying to outdo the previous versions. And companies trying to limit access to the internals for both hiding what's inside as well as safety!
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 254
