跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
MacBook Air Shut Down During New Battery Calibration
I've just replaced the battery in my wife's MacBook Air 2017 with a new one from iFixit.
Installation was easy. I followed the instructions to calibrate the new battery - charged it to 100%, kept charging for a few hours, removed the power and started using it in order to fully discharge.
After a couple of hours of use I put the laptop to sleep by shutting the lid (I had stuff to do). When I went back to it a few hours later I found that it had shut down while asleep.
Battery was still above 80%. When I looked at the logs (powerd log I think) it said that the shutdown reason was code 0 Battery Disconnected. Which it obviously wasn't. Since logging in again (still running on battery) I've used it flawlessly but only allowed it to sleep with the lid open.
I'm still in the full discharge process - so the battery is still working with no problems. Any idea why I had that strange shutdown?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The battery replacement is one of the easiest in this series. The only thing I can think of is if one of the wires from the battery got damaged or disconnected. But that would have been a hard break, not like what you stated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ploppy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 88
