跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2189 个问题 查看全部
Part left over - Camera not working
Hi
I just replaced the front touch screen. Now I have a part left over that I cannot figure out where it goes. I gone through all the videos and pages and cannot find it. It is black with a hole on the upper right side and a folded clip front on the left with a golden end. The rear side is golden completely.
Alternately the camera does not work. I get the closed shutter. I think they are related
Thks for any help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
The part you have left over is probably the grounding clip of the top antenna:
http://guide-images.ifixit.net/igi/x1kpQ...
Have a look at the display assembly replacement step 19&20
iPhone 4S 屏幕更换
I however can not really find a relation between a non working camera and this clip missing but it is worth a try,
这个答案有帮助吗?
得分 0
5条评论:
No the grounding clip is much longer and has been properly installed. This clip is about 1/4 the size of the grounding clip. A shame I cannot attach a picture. Thks
完成的
Possibly then the clip that goes underneath the battery terminal? Have a look at step 4/5 of the following guide:
iPhone4s 电池更换
完成的
Not sure, cannot figure out how it would stay in place.
please check out the part on this link : https://dl.dropbox.com/u/79194393/IMAG00...
完成的
yes that is indeed the clip that goes under the battery terminal. have a look at the following picture. The clip is held in place with the screw marked with the orange circle:
http://guide-images.ifixit.net/igi/tAZJS...
完成的
Thanks, that is it. guess I need to change my glasses. I will keep you posted for the camera ??? Thanks very much for your help.
完成的
添加一条评论
Does anyone know if you can buy this part? Yup my went for a walk an I can't find it anywhere :-(
这个答案有帮助吗?
得分 0
添加一条评论
Yes, if you have not got it yet. I got one from E bay. It does not have the black coating on the clip, but is identical.
http://www.ebay.co.uk/itm/BRAND-NEW-ORIG...
£4.49 in UK
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,501
