跳转到主内容
惠普台式机维修指南。
349 个问题 查看全部
Cant add printer - Print Spooler not running error
I have a HP desktop running Vista 32bit. The printer has stopped working. The printer is fine and so is the USB cable. I have tried a few USB ports that work with other devices. I tried reinstalling driver - I get the popup that driver installs correctly and device is ready to use
however no printer shows up under PRINTERS. If I go Control Panel > printers the pane is empty!
Trying to ADD a printer I get error
I can't reinstall the OS as the system controls a medical machine and the installed application is not easily recovered. System Restore is not enabled either!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 29
5条评论
Thanks dude youre a life saver
完成的
To elaborate on Bobbys answer since mine was a touch different; Windows Search "services" -> Print Spooler -> Properties -> Genernal Tab -> Start
完成的
I had a ѕіmіlаr issue, My printer stopped working.
Print Spooler was not running.
Finally I managed tо rеѕоlvе the рrоblеm
Follow this guide here: http://bit.ly/PrintSpooler
Hоре thіѕ helps
完成的
thanx for solution....my problem for windows 7 solved sucessfully.
完成的
Just uninstall your antivirus. That's all you need. Add Printer back and you're good to go.
完成的
添加一条评论
8个答案
已选择的解决方案
I succumbed to reinstalling the OS and system is fixed now.
这个答案有帮助吗?
得分 11
添加一条评论
最有帮助的答案
*Make sure the Print Spooler service is running ...
1.GO to Start then run and type services. msc and then click OK.
2.Scroll down and find Printer Spooler service under the Name column
3 Right click on Printer Spooler and select Properties. From dropdown menu choose automatic for Startup type. Check Service status, if service is stopped click on Start and than OK button, but if service is started first stop it with Stop button than click on Start and OK.
*Also..check for dependencies... while in the Print Spooler service properties..
1.Click the Dependencies tab. The first box lists all of the system services that must be running for Print Spooler to start. These are the dependencies.
2.Make a note of each service, click OK
3. Now go through the list and start each service upon which Print Spooler is dependent( if the service is not already started). If a service was not started, right-click it, click Properties and then confirm that the Startup type is Automatic.
这个答案有帮助吗?
得分 45
23条评论:
Thanks Ronnie, I have checked that the PrintSpooler service is running and have stopped/started it. I will check the dependencies though as I have not done this yet.
完成的
The printspooler dependencies are running
完成的
it works ,, tnx a lot men^^V
完成的
it really workssss...............thnx dear
完成的
thank you very much...
完成的
显示更多的18条评论
添加一条评论
*Print Spooler will not just stop for any reason.
The print spooler is set up to restart 5 times after a failure. If the spooler continues to fail, there is an underlying issue causing it to fail.
Go to: c:\windows\system32\spool\printers
Delete all files inside this folder.
Try and restart the spooler and monitor the event log to see if it is still failing.
If it is still failing, the issue is a corrupt printer driver.
Go to: c:\windows\system32\spool\drivers
If your OS is 32 Bit go to : W32X86
If your OS is 64 bit go to : x64
*WARNING - THIS WILL DELETE ALL INSTALLED PRINTERS*
Delete all files in this folder and reinstall your printer.
这个答案有帮助吗?
得分 14
15条评论:
Yeah agree there must be a reason... I have already deleted the files from spool\printers and will try deleting the drivers manually from \system32\spool\drivers\W32x86
完成的
deleting the \drivers\W32x86 folder does not help.
完成的
Try this :
1. Start > Start Search > C:\Windows\System32\spoolsv.exe (Right click > Properties)
2. Click on Security Tab > Advanced > Owner. Take ownership of the file and give full permission to the file. Once done, close
everything and try to start the service again.
3. Delete the following folders, including all contents.
c:\windows\system32\spooler\printers
c:\windows\system32\spooler\drivers
4. If this fails, sometimes Windows 7 Pro X64 has issues with IE9 and the spooler
Go to the Control Panel > Internet Options > Advanced Tab > Reset > Tick Personal Settings
完成的
5. If this still fails, you will need to aquire a working registry set from a working machine.
To do this;
On the donor machine Copy the C:\Windows\System32\Spool directory
On the donor machine run Regedit and copy HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print right click it
choose 'Export' and save it somewhere, make sure it has a .reg file extension
Replace tha bad machine's C:\Windows\System32\Spool directory with a copy of the fresh one
Find the backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print registry settings from the good
machine, and double click the file to enter the info into the registry on the (now better) bad machine
Restart the print spooler service ( Start > Type in cmd > Right Click on cmd > Run as admin > and type; net start spooler)
If you cannot souce these files from a working machine, let me know and I will upload a fresh reg copy for you :)
完成的
thanks jclark - I will look at the options you have suggested. As luck would have it I have access to a "donor" machine tomorrow so I will copy the files and registry as you suggest and see where it gets me. The systems are essentially identical however the printer installed on the "donor" system is a different model (both syst have Brother printers) BTW you mentioned Win7 my system is Vista.
完成的
显示更多的10条评论
添加一条评论
I had the Spooler Printer not running problem and used the following from above that worked like a charm;
1.GO to Start then run and type services.msc and then click OK.
In place of #3 I simply clicked on Printer Spooler and it presented it's settings on the left side of the box, and I just clicked on Start the Service...
worked like a charm...not sure why the printer spooler stopped working, possibly from some recent power spikes from power outages (but I could be wrong on that).
这个答案有帮助吗?
得分 2
1条评论:
U r awesome. Thannks
完成的
添加一条评论
Hi Guys
there is last solution in case all the above is not solving the issue
Go to C:\Windows\System32\spool\drivers and delete all the files which is belong to the printers and restart the spool printers > after that go and add your new printer .
regards,
Ahmed Ali
这个答案有帮助吗?
得分 0
添加一条评论
In Services, right-click Print Spooler and then click Properties.
Make a note of each service, click OK and then start each service upon which Print Spooler is dependent, if the service is not already started. If a service was not started, right-click it, click Properties and then confirm that the Startup type is Automatic.
这个答案有帮助吗?
得分 0
1条评论:
@wefixcanon please keep advertising out of your posts.
完成的
添加一条评论
Wow. Thanks. I was almost about to discard my printer. God bless you guys
这个答案有帮助吗?
得分 0
添加一条评论
i was in trouble for one week with the spooler issue , i just resolve the problem with removing the dependancy HTTP service from REGEDIT , i kept only the RPC service .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richdave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 352,489
