跳转到主内容
加入维修社区 - 创建账户
Xbox Series S是微软于2020年11月10日发布的轻巧纯数字游戏主机,与Series X属于同世代产品。本页面包含 Xbox Series S的维修指南、拆解信息,以及疑难解答。
HDMi needs replaced and I have no clue how too
I got my Xbox s last August and it stopped working in December it would turn on and I could hear the Home Screen with headphones in my controller but I can’t get a picture I’ve bought new hdmi cables but it doesn’t fix it would I be better replacing the part myself or taking it for repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
So little update I plugged my Xbox in to see if the issue was still ongoing and it was outs of frustration I slapped the top of my Xbox and it started working again I think I might be repair god
完成的
添加一条评论
1个答案
已选择的解决方案
It depends on how comfortable you are with soldering and disassembly. If you feel like you can do it yourself, go ahead! If not, there are plenty of repair shop that would be happy to fix it for you. If you plan to do it yourself here is the guide and here is the part (Or this part) you will need.
You also might need soldering tools.
If the kit linked is missing something just comment with what it is and i'll add it.
Happy iFixing.
Replace a corroded, dirty, or damaged HDMI port for an Xbox Series S model 1883 14 digit serial number gaming console.图片
产品
Microsoft Xbox Series S Model 1883 (14 digit serial number) HDMI Port - Genuine
$17.99
这个答案有帮助吗?
得分 3
5条评论:
Thank you for the advice I do have a mini soldiering kit and micro tools but no kidding yesterday I plugged it in to see if the issue was still ongoing it was so I got mad and slapped the top casing on the Xbox and it started working again 😂😂
完成的
@kerr35832 Sometimes it just needs motivation. Glad it's working!
完成的
Could be a bad joint on the hdmi port connector on the board that needs reflowed and by banging it has knocked it back together. Whilst it's on, gently move the hdmi cable at the port. Don't go mad just tiny movements to see if the picture goes off again. The retimer chip could also be on its was out. Not something you could do at home unless you have a hot air station.
完成的
My gf damaged the hdmi entrance can I get info how to fix it
完成的
thats exactly same thing here
完成的
添加一条评论
添加你的答案
Kerr 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 141
过去 30 天: 617
总计 4,773
