跳转到主内容
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1092 个问题 查看全部
The connector from the keyboard to logic board broke.
I have a power book g4 17 inch and when i was taking apart the computer to put a new hard drive in I accidentally broke the connecter on the logic board which connects to a cable from keyboard and tackpad. Is there any way of fixing this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个回答
已选择的解决方案
Unless you can make a good connection with the connector you will probably have to replace the logic board. If you can make a solid connection it may be possible to tape the cable to the logic board. Good luck. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Could you take a high resolution pict of the damaged connector then upload the pict in your question ? It would be easier to give a good answer if we can see the damage.
这个答案有帮助吗?
得分 2
评论:
Good idea. Ralph
完成的
添加一条评论
添加你的答案
alex von 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 768
