跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—在2017年6月上市,这台入门级MacBook Pro保留了它的实体功能键(相对于OLED Touch Bar)。
Headless mac stuck on apple logo screen
My late 2017 MacBook Pro screen went black. I assumed the MacBook was coming on since the caps lock light would light up. I tried various reset keys and nothing worked. Local apple repair said screen went out. Went down the headless mac rabbit hole and determined this could work for me with an external monitor. Took the Mac screen off and connected to external screen. I’m assuming mac is coming on as the external screen shows an apple (without a loading bar) and the caps lock light still comes on. I’ve tried various reset keys again and nothing is working. I’ve also tried the command f1 to allow screen mirroring and that didn’t work either. What should I do next? At the very least, I need to access the data and get it backed up or onto another device. How is the best way of going about that or have I already lost the data? Can I still fix the Mac and use it headless? Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your stuck! The lid its self has a function in altering the video output from the internal to the external.
As it's not shut (clam shell mode) the external won't become the primary display. So how is this done is the clue and the answer!
The logic board has a Hall sensor which senses the magnetic flux from a magnet which is embedded into the lid. Here's the location on the logic board
Now this is the backside of the logic board pressed into the palm rest just above the ports. So getting a rare earth magnet and placing it over this location will switch the video output to the external as the primary display. Hopefully that fixes your issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
April Weiss 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 700
