跳转到主内容
加入维修社区 - 创建账户
2017 年 6 月,Apple 更新了其 13 英寸 MacBook Air,配备了更新的 Broadwell Intel Core i5 处理器,性能和电池续航时间均略有提升。
New battery issue. Prolonged charge time and abrupt shut down
I installed a new battery from iFixit (Serial Number: C01514329YEF90NA2). I followed all directions from the iFixit tutorial. Initially the computer seemed to work fine, but now it seems to take forever to charge and then seems to rapidly discharge when it is being used with simple applications. Also it has started to just shut down for no apparent reason. The shut down only occurs if on battery and does not occur if it is plugged in. Is there something I should do to "reset" the computer? Thank you
Update (06/04/25)
Is this is what you wanted? Plugged in and charging.
Thanks for your help.
CooconutBattery indicates Battery Charge 6702 mAh/94%
Battery Overview of [MacBookAir7,2]
Generated on [Jun 4, 2025 at 4:00:25 PM] by coconutBattery 4.0.3
Device Details
Model MacBookAir7,2
Serial FVFXQ453J1WT
Manufacture Date Nov 19, 2018
Battery Details
Serial C01514329YEF90NA2
Manufacturer ifixit
Manufacture Date N/A
Cycle Count 7
Current Capacity (7128 mAh / 7000 mAh)
Health 102%
macOS Battery Status Good
Reported Failures None
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
!st off I would try to reset the SMC & PRAM, then run Apple Diagnostics with the charger connected (Power Up + "D" key until the prompts), then install CoconutBattery and add the screenshots to your question with any info provided from the diagnostics. Maybe some further info can be found in any system logs.
这个答案有帮助吗?
得分 0
2条评论:
Reset SMC and PRAM. Apple Diagnostics came up with no issues. Problem - MacBook Pro Air 2017, just shuts off, even when actively using an application. Must start up from scratch. Also it seems that it takes longer to fully boot up. My next move was to purchase Malwarebytes and see if I have any virus issues. Make sense?
完成的
@bobi62689 - First off Malwarebytes is a great App, but won't help you here! We really need to see that screenshot of CoconutBattery main window while it's under charge. That is the direction I would go for your issue here. Just click on the Blue URL Link in Livfe's answer.
完成的
添加一条评论
添加你的答案
Bob I 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 174
