跳转到主内容
修复你的物品
维修的权力
配件 & 工具
型号A1367,闪存容量:8、16、32及64GB
1306 个问题 查看全部
问题已关闭
Why did the screen replacement fail?
I was replacing the screen of the iPod touch, and before pressing the new screen in, I checked it. Both the LCD and digitizer worked fine. I turned the iPod back off and went to press the screen in, when I noticed the cable was unplugged. I plugged the LCD cable back in, and now the iPod won't turn on? Tried plugging it in and still nothing. Don't know what happened. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
3个回答
Try doing a hard reset. Hold the power button and home button at the same time for 10-12 seconds, then release the home button and keep holding the power button. It should reboot.
Also, battery may be dead.
这个答案有帮助吗?
得分 0
评论:
Yeah I feel like a moron. Battery was dead lol. I guess I should have checked that. But now I've got s bigger issue...the screen doesnt seem to fit. I've never done s 4th gen so I never had this issue, and I don't want to push it too hard because I don't wanna shatter it
完成的
添加一条评论
Be carefull with iPod touch 4, because it's really hard to have a good screen and place it correctly
这个答案有帮助吗?
得分 0
添加一条评论
If the screen doesn't seem to be fitting properly, the first thing I would check is if the metal housing is bent. it is very common on those iPods when they are dropped and the screen gets broken, the housing on the corners also gets bent which makes the new screen not fit properly. Check that first. If it is bent you can carefully bend it back with a pair of pliers. the next thing to check is the plastic bezel that supposed to go around the glass. it may be warped broken or missing.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 780
