跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Antenna cable is broken. Do I have to replace it?
While replacing the inverter on Macbook A1181 Early 2009, I noticed the gray antenna cable is sliced and the black one is nicked. Do I have to replace them or can I remove some insulation, twist and put some electrical tape on it? A friend just suggested soldering the two pieces together. Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Well, replacing them will guarantee a fix and guarantee that no further problems arise.
Fixing the wires yourself will cause any variety of problems if you don't do it exactly right. And thus end up costing you a lot more money to replace the hardware they have damaged.
Personally, I'd replace them.
If you fix the wires incorrectly it will cause problems and I just wouldn't feel comfortable with my abilities to not screw some minor thing up.
However, if you feel absolutely confident with your soldering and repair abilities you can certainly fix them yourself.
But I wouldn't recommend attempting it unless you have a lot of direct experience repairing and working on computers, have screwed up a couple so you know what not to do, and know precisely what you're doing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BridgetSchober 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 526
