跳转到主内容
加入维修社区 - 创建账户
一款中型 Jeep SUV,于 2006 年至 2010 年期间销售。有 XK(汽油)和 XH(柴油)两种版本。
What could be leaking oil if the oil leaks only when it’s running?
So I bought my jeep at an auction and I’m replacing one thing at a time, the diagnosis reads a lot of misfires so I replayed all 8 spark plugs, 2 odd the coil packs and the cam shaft position sensor and now when I turn it over oil is leaking bad from somewhere under the passenger side of the engine, I can’t tell where it’s actually leaking from but the mechanics wouldn’t even diagnosis it because it was leaking too much oil?? What could it be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@amydunlap what exact year and engine size is this? You are not saying if it leaked oil before you replaced the cam shaft position sensor. Double check your work to make sure you did not forget to tighten or connect something. Normally I would have said its a seal but if it leaks that much you are most likely blowing the oil out of your block somewhere.
由完成的 分享
添加一条评论
1个答案
If its only leaking when running you've got a crack/hole fairly high up on the engine block
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy Dunlap 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 36
总计 276
