跳转到主内容
Samsung's third iteration of its Galaxy Watch with a newly integrated BioActive Sensor and a classic design. It was released August 27th, 2021. Model SM-R895F, 46 mm, LTE version.
New and old batteries both refuse to charge
I purchased a new battery from Ifixit for my Galaxy Watch 4 Classic. I followed the installation guide very carefully (三星 Galaxy Watch4 Classic 电池更换) and had no issues.
At first it worked fine: I charged it up, ran it down completely as instructed, and then went to charge it. The watch would charge for a few seconds or minutes, maybe showing 0% to 3%, then stop. If I tried again (and again) I'd get the same results.
Finally I gave up, assuming the battery was faulty, and put the old battery back in. It had about 14% power but immediately ran down to nothing and the watch shut down. It's refusing to charge again.
What am I missing? Could there be a bad connection to the battery somehow? Damage to some other part of the watch?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
have you checked the charging port? I messed mine up when I changed my galaxy watch battery
这个答案有帮助吗?
得分 0
3条评论:
Thanks, but it charges wirelessly. There is no port!
完成的
@brad3488 as in that wireless connector, check if it works on another galaxy watch
完成的
Ahh, I understand! OK, I opened it up again, cleaned all the contacts between the battery, charger, and motherboard, raised the springy contacts a bit, and closed it again. It seems to be working now! Thank you so much!!
完成的
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 245
