跳转到主内容
加入维修社区 - 创建账户
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Need Help Diagnosing PS3 Controller Ghost Inputs (MCU V3.5x 1.12)
Hello, I’m struggling with ghost inputs on a DualShock 3 (MCU V3.5x 1.12) with a Toshiba T6UN6EFG-002 Japan 0833EGIF0461ZAO. I’ve tried cleaning and reassembling, but the issue persists. Any advice would be appreciated!
Problem:
  • Ghost Inputs: Pressing one button triggers multiple inputs (e.g., Square causes random b, w, [, ], a, 1 combinations.). [ for context: the reWASD mapping is in the photos link ]
  • Pattern: After connecting via USB, the controller outputs [[[]]]]] after ~15 seconds.
  • Multimeter Fix: Dragging the red(signal) probe across all pins temporarily stops the issue.
What I’ve Tried:
  1. Disassembled, cleaned PCB
  2. Tested button continuity with a multimeter (Square=TP30, X=TP31, TPs to Toshiba pins, connectors up to the white boarder).
  3. Confirmed the issue occurs wirelessly and via USB
Limitations:
  • No soldering tools yet.
  • Can’t identify shorts or damaged resistors.
I removed everything and left the PCB only to be sure that the problem isn't from anywhere else. I bridged the pins with the help of wires, paper clip and other metal conductive object.
Any tips what to look for? What else can i try? Any ideas where the problem could be?
Link to photos: https://mega.nz/folder/oigjFaiI#7NXMg2_7...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
It's a common issue for the Dualshock 3 to ghost after some time.
I replace the Button Circuit Membrane all the time and this actually always work.
So, I recommend to do this and see how that goes.
If you need any guides, please let me know!
Thanks!
这个答案有帮助吗?
得分 0
4条评论:
Would replacing the membrane work even when i tested it through the PCB and still gave errors?
完成的
For me it does. It's worth the try! Usually this is the golden fix.
完成的
@dan0 k then. i will order a membrane from ali and see how it goes
完成的
Alright! Please keep us updated! Thanks :)!
完成的
添加一条评论
添加你的答案
User 1 Here 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 252
