跳转到主内容
加入维修社区 - 创建账户
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
How to rewire fuel tank pressure connector
How to rewire fuel tank pressure connector?
A rat chewed through the cables.
Should I use a butt connector with solder or something else ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I'm glad you know what you are talking about. I,m betting no one else does.
完成的
@bryan52849 rephrase your question. You ill need to let us know the exact year and engine size for your pickup. Then you need to tell us what is wrong with it and you need to tell us what you have already tried and checked. Your current question is not clear. at all. Nobody will know what you are referring to as a fuel tank pressure connector
完成的
添加一条评论
1个答案
@bryan52849 I would use some butt connectors and after crimping project those with either some electric tape or some heat shrink. You just want to make sure that you keep possible corrosion to a minimum.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 78
