The Craftsman 315.114852 is a portable power tool designed for a range of drilling and driving applications. This page provides detailed information about its features including a 1/2 in., 19.2-volt battery, a keyless chuck, a two-speed gear train, and a 24-position clutch, along with repair and usage guidance.
My Craftsman drill, model 315.114852, "Torque Adjustment Ring" is stuck and I can't turn it to select different torque settings. How can I fix this so I can use different settings? Thanks.
Try using canned air while tapping the torque adjusting ring with a rubber mallet around the ring. Dirt may have entered and plugged the locking/unlocking mechanism from operating freely. You might have to try using WD-40 lube.
由 F Dryer 完成的
