跳转到主内容
苹果Magic Mouse鼠标是由苹果公司制造和销售的多点触控鼠标。它于2009年10月20日首次公布和销售。
Multi-touch Gesture Control is out of service
Hi! I have this Magic Mouse Gen 1, and it has a problem that’s related to Gesture Control.
It sometimes responds to what I did, scrolling, tapping, but usually it’s almost nothing to smoothly control.
I’ve just been expecting this is hardware problem, so what do you think to fix this problem?
Appreciate your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Not much you can do for this rodent.
Make sure the battery contacts are clean of any junk and often times they get coated with a thin film of oxide which you can't see. Use a fresh (still soft) pink pencil eraser stick polishing the contacts within the holes and the plate side as well. Some batteries don't make good contact so you may need to try a second set.
Gesture Control Is dependent on a sensor which hugs the curved surface of the top which you can see in Step 9 in the Magic Mouse Teardown unless it's damaged in some way there's nothing you can do to fix that.
As far as the tracking the LED and sensor on the bottom can get dirty enough you'll loose the tracking of the movement as you shift the mouse. A small cotton swab can wipe the lenses and some compressed air to push it away.
这个答案有帮助吗?
得分 0
3条评论:
Thank you for your answer.
I've just searched for other questions and probably found a solution.
I’ve experienced battery leak ago, and I cleaned up contacts and battery cases, but I haven’t seen inside of mouse yet, so perhaps the leak can be damaging them.
How dou you think of this? Thanks
完成的
@liberasspiritas -If you jump down to Step 7 in the Teardown you can see the sensor is connected to the base logic board. It's possible the leakage damaged that connection.
完成的
@danj Thanks! I’ll try it later!
完成的
添加一条评论
添加你的答案
Libertas Spiritus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 112
