跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
turn on and then immediately off
My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 22
6条评论
trun on problams
完成的
plz talk to me
完成的
Ha (that happiness to me to)I don't know how to fix it
完成的
How to fix a DS lite that turns on and instantly off
完成的
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
完成的
显示更多的1条评论
添加一条评论
8个答案
最有帮助的答案
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
Nintendo DS Lite
Though there is another apparent option which centers around possible hinge damage. Does it appear that there was any damage to the hinge in the fall?
If so you may just need to replace the casing and one of the screens to rectify the issue. In which case the above guides would also be useful.
Also, if it turns out you need replacement parts, this is a good spot to start looking.
这个答案有帮助吗?
得分 13
5条评论:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
完成的
That´s the answer I was looking for. tnks
完成的
it work on my ds
完成的
turn on problams
完成的
Lol, it's been a long time since literally "jiggling the cables" was a solution. Disconnect, and reconnect, the 3 ribbon cables, works like a charm.
完成的
添加一条评论
one of the connectors is not connected anymore
这个答案有帮助吗?
得分 1
添加一条评论
hold the power switch on a maximum 1 hour and keep the ds game inserted.
if your daughter wants swap the ds game your daughter will need a gba game
这个答案有帮助吗?
得分 0
添加一条评论
maybe it was just from the fall
这个答案有帮助吗?
得分 0
添加一条评论
Hi, if you’ve got no flash screen, consider to try my fix here.
The DS won't turn on. Green light flashes for a second.
这个答案有帮助吗?
得分 0
添加一条评论
The problem might be in the battery compartment
这个答案有帮助吗?
得分 0
添加一条评论
i will try shaking mine and see if that works, since i might just get a new one, if we can't fix it
这个答案有帮助吗?
得分 0
1条评论:
i did not work :'(
完成的
添加一条评论
My aunt’s DS lite’s power switch is broken. I would slide it to the on side but then it just moves to the off side. Is that supposed to happen?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
khan786 将永远感激不已
浏览统计数据:
过去 24 小时: 21
过去 7 天: 168
过去 30 天: 767
总计 82,238
