跳转到主内容
Repair and disassembly instructions for Jura Impressa F50 fully automatic coffee machines
It's saying drip tray not fitted
It was pulled apart and put back together a screw was misplaced and now it's saying drip tray not fitted error, unsure where the screw went or came from just know that 1 is missing. What screws missing could cause this error directly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The trip tray should trigger a microswitch in the machine, letting it know if it is in place or not. It sounds as in your case this switch is not in the correct place and therefore not being triggered.
I think the switch is located at the right side above the water pump, and I assume one of your leftover screws is from the bracket holding the microswitch (and the solenoid drainage valve) in place.
这个答案有帮助吗?
得分 0
1条评论:
Thank you David I will pull it out and have a look at what you've detailed above I appreciate the response so very much. You wouldn't happen to know where to buy spares or screw sets by chance would you?
完成的
添加一条评论
添加你的答案
Victor Jnr Slifkas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 89
