跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
DS4 circle and traingle are bound together(JDM040).
Hello, I've had a problem with circle button(it did not work), I assembled and disassembled gamepad but only i achieved was some weird issue when my triangle was pressing both keys. I decided to replace my conductive flex. My circle button started working, but it is still bound together with triangle (both buttons are pressed when one of them is pressed). When you look at JDM 040 flex, both buttons have conductive trace with each other, I am thinking about breaking it, but I am afraid both keys will stop to encode correctly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Make sure you have the exact right model replaced for the Button Circuit Membrane. If this is the case, please clean the motherboard (the pins that will push against the button circuit membrane) cleaned with isopropyl alcohol. Otherwise, replace it again and see if that works.
If all of above failed, replace the rubbers as well to see if that makes a difference. Otherwise it is something on the motherboard (but this most of time not the case.
这个答案有帮助吗?
得分 0
2条评论:
Thanks I will try to clean connections once more but it seems not much can be done.
完成的
My pleasure! Good luck! Hopefully you will get it fixed!
完成的
添加一条评论
添加你的答案
Kris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 121
