跳转到主内容
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
loose hinge MacBook air M1
Hello, I have loose hinge above 90%, can it be tightened on MacBook Air M1?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Where is the hinge(s) lose at? Middle case side or LCD side? Review the guide at Step 13 2020年下半年 13寸 MacBook Air 显示屏更换 and you can check and tighten the hinge screws there. IF they have broken or become lose due to the laptop likely being being carried around with the screen open which could easily over flex the hinge mechanism breaking their tension, then you would need to find replacement hinges. I am not so familiar on these models so I cannot provide an accurate answer. I am sure that @danj will chip in with some good news.
完成的
添加一条评论
2个答案
已选择的解决方案
The MacBook Air M1 hinge isn't user-adjustable—tightening requires professional service as it involves delicate internal components.
这个答案有帮助吗?
得分 -1
1条评论:
@rashmikand95190 - Remember the goal here is self service when it’s a simple issue. When it’s more involved outline the problem and what’s involved to repair it. As the sites name implies: I Fixed It
Sending someone to a shop straight off without any details is no better than sending someone to the hospital just because the persons finger is bleeding without knowing if it’s a simple paper cut vs half torn off.
完成的
添加一条评论
最有帮助的答案
The hinges on the newer MacBooks are a two piece design, a press fit pin into the lid and a clutch spring which wraps around the pin to offer the friction. Only the clutch side offers the mounting interface to the uppercase.
So… either the screws them selves are loose reference Step 12 in this guide 2020年下半年 13寸 MacBook Air 显示屏更换 or the press fit pin has become loose within the lid. Often times the hinges work but the last bit of closure is where you notice it’s a bit loose, that’s a sign the pins have failed which will require replacing the display assembly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jan Dvorak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 50
总计 50
