跳转到主内容
Whether your flute won’t play, the keys are sticky, or you have a broken key altogether, there is a way to repair it.
Flute won't speak beyond bottom two octaves.
I am a very experienced flutist, and was testing a flute getting sent to a reservation. The bottom two octaves work well (once I hooked the springs back up). Above the staff can get C#, D, sort of Eb, F not at all. Wondering what could be causing this. Bent place on inside of where foot joint is attaches that I haven't smoothed out yet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Just like the standard holes which you cover with your fingers the seal of the hole needs to be complete. The lower holes often have a key rod extension and key pad these also need to offer a tight seal to work properly. Check the cork/silicon seals and spring of the given lifter as well as check the head join cork as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Enid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 50
