跳转到主内容
加入维修社区 - 创建账户
Part of the Handycam series of cameras. Manufactured in 2007 by Sony.
How do I adjust the laser power on the DVD?
So, my camcorder can on read DVD-R, Not DVD-RW. I had the exact same model a few years ago that wrote the video to those discs, and the discs are fine because they read to my computer. Also, I have checked that the spindle, laser carrige assembly and laser are working. Also, a the CD-R mentionined above worked fine on my computer, but needed cleaning to work on the camcorder, which leads me to beileve that the laser is weak, Also just curious, what is the difference between DVD-108 and DVD 108E. Both of mine are just 108
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
[image|3612201] Found the potentiometer 👍
完成的
添加一条评论
1个答案
已选择的解决方案
@vighneshrath check for a trim pot on the laser assembly. On a laser you do not really adjust the voltages but the resistance. You need to know what it is before you start changing values, otherwise you are going to burn out your laser. So, look for a trim pot on the laser flex to board VC483, also check that board. Adjusting lasers is usually not a lasting fix. Personally, I would replace the laser since that would be the safer alternative. Here is the guide for that Sony DCR-DVD 108 DVD Laser Replacement.
Now, if you want to further work on the laser diode etc. download the SM level 2 and 3 from this page Sony DCR-DVD 108 right under the Document heading.
这个答案有帮助吗?
得分 1
4条评论:
Thank you so much for responding! Hopefully this works.
完成的
Just adjusted it, and it worked. For anyone else, turn it clock wise by very little. If doesn’t detect the disc, turn it more. It should eventually read but pop up with the error Cl:13,02.clean the disc, if that doesn’t work; turn it more.
完成的
Can someone post a tutorial? It's very difficult to know the exact position and I'm scared of burning out the laser
完成的
@lilacinfo post some good pictures of your lasers layout etc. so we can see the trimpots and hopefully can get you some more pointers. Number one is you NEED a multimeter.
完成的
添加一条评论
添加你的答案
Vighnesh Rath 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 38
总计 357
