iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1503 个问题 查看全部
How many screws are there in iPhone 3G?
I'd like to know how many screws there is in an iPhone 3G to make sure I didn't loose any of them. Anyone knows?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
评论:
I guess I'm screwed then, get it? Screws. Not funny but seriously, anyone who teardown their phone without counting the screws or remembering the order is basically screwed, I don't know how to move forward from here. Since there since to be no knowledge to help me out
"Since there seems to be no knowledge to help me out" - Correction
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
2 by the dock connector on the outside
8 in the logic board
2 for the vibrator
2 for the lock button
4 for the volume/vibrate buttons
4 for the headphone jack assembly
1 for the SIM card ejector
3 for the dock connector assembly
6 (I think) in the screen assembly
=32
Be careful, they're different lengths, some aren't threaded all the way to the head, etc. Should have kept track of where each went, but good luck.
这个答案有帮助吗?
按维修分数 2
评论:
Ok, that deserves an up vote +
添加一条评论
I seriously doubt if anyone knows the answer. Put down a couple of strips of adhesive tape and place the screws on it as they are removed. Take digital pictures of each step and you should have no problems with reassembly. Here's the tear down: iPhone 3G Repair
这个答案有帮助吗?
按维修分数 1
添加一条评论
337
这个答案有帮助吗?
按维修分数 1
评论:
I stand corrected. Someone actually did count them ;-) +vote for the effort
I was just kidding. (Maybe I should vote down my post.)
I doubt you can downvote yourself. If I did it it might go negative. I'll leave you a note the next time I start to up vote you and don't.
Nope, doesn't look like I can downvote myself...I tried. :-)
添加一条评论
If I had to guess after looking at the teardown, I'd say somewhere in the neighborhood of 35-50
这个答案有帮助吗?
按维修分数 1
评论:
Thanks for the effort, though I need an exact number.
添加一条评论
添加你的答案
Henrik 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 4,424
