跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Touch bar works but no light. What's broken?
A friend has an A2338 whose touch bar works but doesn't light up. I've tried to troubleshoot software issues but the problem persists.
I would like to repair it, since repair shops are hard to come by around here. But I'm unsure were to start, I'm inexperienced all things apple. Can I replace just the touch bar? Or do I need to go with a whole upper case replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Well I will suggest you to Ensuring your MacBook Pro is running the latest version of macOS can fix many Touch Bar issues. So Please check if your macbook is updated to it latest version if it is not updated to the latest version then I will suggest you to update it to its latest version.
这个答案有帮助吗?
得分 0
1条评论:
I've already gone through several software troubleshooting steps, including updating to the latest version (or verifying that the latest version is installed) without success.
I'm confident it's a hardware issue
完成的
添加一条评论
Sadly the panel its self has likely failed and will need to be replaced. Unlike a LCD panel which has a light source behind it OLED panels emit their own colored light per pixel. Here we have a matrix of lines that run across the panel to supply the signal and needed power for the panel to light up. A good bang or liquid spill can kill the panel. Here’s the guide MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal besides getting a new panel as the cheaper option you might just want to get a new uppercase if your battery is also close to the end of its life as that’s less work and frankly quicker!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Manuel Luka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 114
