跳转到主内容
加入维修社区 - 创建账户
Little machines by Jura. There are different models, but the repairs are almost the same.
My Ena 3 is no longer alerting when coffee grounds container is full
Everything is working well with my Ena 3 old machine except that now the alert is no longer working when the Coffee grounds container is full. Does anyone have some ideia ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@allancarvalho this sound like a case to be solved by our coffeemaker guru @vauweh
完成的
添加一条评论
1个答案
最有帮助的答案
@allancarvalho As far as I remember, there is no sensor for coffee grounds. The message is generated by counting the number of cups. For me it's a bit of a mystery why the machine can no longer count and otherwise works normally. The only thing I can advise is to thoroughly clean the brewing unit, which is always a good idea. This video of a perfect restauration (its an ena 5) will help.
这个答案有帮助吗?
得分 2
1条评论:
Thank you @vauweh. I'm pretty sure my machine doesn't have a coffee bean sensor. It seems to me that the issue is with the cup counter. Could it have stopped working, or is there a maximum cup limit? Is there any way I can check how many cups have been counted?
完成的
添加一条评论
添加你的答案
Allan Carvalho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 165
