跳转到主内容
Released in June 2022, model number T779W, codename "Challenger_TMO", has an integrated stylus.
Why is my TCL showing the headphones symbol
My phone shows the headphones symbol and won't play any sound through my phone speaker
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @reixy4k
Can you hear any sounds if you plug a set of headphones into the phone?
If you can then try plugging/unplugging the headset of few times to see if this resolves the problem. It may be a sticking contact inside the headphone jack in the phone that was causing the icon to appear when nothing was plugged in.
If you can't hear any sounds in the headset when it is plugged in and trying to clear the problem as suggested above doesn't work then most likely the headphone jack in the phone needs to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
reixy4k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 63
