跳转到主内容
9 月 24 日发布的苹果 2021 旗舰智能手机配备 6.1 英寸 ProMotion OLED 显示屏、全新三镜头后置摄像头系统和 5G。iPhone 13 Pro 是 iPhone 12 Pro 的继任者。
Display Assembly Adhesive For iPhone 13 pro
Hi everyone,
I want to replace the battery on my iPhone 13 pro (A2638) and I just need the battery and the Display Assembly Adhesive (I already have the tools) however I can't find the adhesive for the 13 pro sold separately.
Should I use the iPhone 13 adhesive??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You don’t need to use the iPhone 13 adhesive—the correct iPhone 13 Pro Display Assembly Adhesive is available here:
👉 iPhone 13 Pro Display Assembly Adhesive
Since this one is specifically labeled for the 13 Pro, it’s the right choice. Just make sure to remove any old adhesive before applying the new one for a proper seal.
Good luck with your battery replacement! 🔧📱
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 13 Pro.图片
产品
这个答案有帮助吗?
得分 1
2条评论:
Hi rstranic, thanks for replying
Unfortunately it's not showing on the Australian store :')
Maybe it's out of stock
完成的
Hi,
After a quick search on Google, and Chat GPT, I found out that there are no actual differences in screen size between 13 and 13 Pro, besides that the frame is made from different material.
I would go ahead and get the 13 version. Even if it's not 100% the same, it is quite soft, and when you remove the plastic from the adhesive, you can maneuver it a bit, it wont stick too much before you heat it so don't worry.
it is much better than nothing (at least it will help for the dust).
Good luck!
完成的
添加一条评论
添加你的答案
Scarfm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 216
