GE Monogram 48" side by side air circulation question
The result of this issue (apparently improper circulation) is that the freezer goes into a deep freeze while trying to make the fresh food section 40f. The freezer has evidenced a temp of -13f or similar.
In the process of isolating the cause, I have removed the Styrofoam extension from the damper (see graphic) in the area of the red ellipse/circle. With that removed the freezer and fresh food temps are normal at -1f and 40f for days/weeks on end.
If I reinstall the styrofoam the issue of the deep freeze begins and never corrects itself until the styrofoam is once again removed.
The styrofoam in question is located in the area of the red ellipse/circle in the attached graphic. The air is supposed to move to the right and then down the center section of the back wall. I get no air moving when I hold a long piece of cellophane in front of the closest opening.
I looked to the right inside the top of the back wall opening with a mirror and flashlight and all looks clean and open.
Also, I have replaced the damper and verified it is opening and closing. It has always appeared open when the issue is present.
Any ideas?
Update (03/11/25)
And here is a pic of the styrofoam part in question.
Hi @nick29463
What is the model number of the refrigerator?
由 jayeff 完成的
Sorry, it's ZISS480DRHSS
由 Nick 完成的
