跳转到主内容
The Samsung Captivate is a USA-exclusive flagship Android phone in the Galaxy S class of devices, released by Samsung in March 2010 for use on the AT&T network. Identifiable by model number SGH-I897.
Difficulty charging, does not power on.
I bought this Samsung Galaxy S Captivate sgh-i897 from a guy. I don't know what he did to it he said he was messing with something, the phone is not powering on. When you charge it, the screen is back on and shows it connecting to the computer while I am charging it to the wall. I was wondering if you had any ideas of what is wrong with the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
what if the screen does not turn on or power up when you try to turn it on
完成的
添加一条评论
5个答案
最有帮助的答案
Sounds like the battery is either not getting charged, or does not hold a charge. You can try and measure the voltage at your battery connectors, see what you get when the phone is plugged in. I'd start with a new battery and continue further trouble shooting from that point.
这个答案有帮助吗?
得分 2
添加一条评论
Before buying a battery you should try rebooting the phone hold down the power button and both the volume up and down buttons, you should get a screen that gives you the option to reset the phone and clear a few things such as the cache and then reinstall stuff. The previous owner probably tried out a task killer that didn't recognize certain things that should be running when the phone starts up and stopped them from starting up or deleted them completely. I had to do this with my phone my phone would power on but shut off with a full battery and wouldn't turn back on without first doing a battery pull and having it plugged in another problem this fixed not being able to receive picture messages too. I'm not pro or nothing just have my one phone and am learning as I go but I hope this helps make sure you have your contacts backed up before the reboot clear and reinstall. Good luck
这个答案有帮助吗?
得分 1
添加一条评论
nope,it doesn't reset or do anything like volume buttons
这个答案有帮助吗?
得分 0
添加一条评论
Ya mine does the same I don't know what to do
这个答案有帮助吗?
得分 0
添加一条评论
u need to flash it, wat i mean it needs updated software only tht
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dante 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 3,728
