Upgrading my PowerBook’s logic board?
I have a 17” 1.5 GHz PowerBook G4 that has an issue with the graphics card and the TAS chip. I’d like to replace my logic board with a new one, but I noticed that the 17” 1.67 GHz model (low res) has very similar hardware parts. Will it be possible if I can replace my logic board with the 1.67 GHz one and make it fully functional without replacing any other hardware parts?
Here’s a good listing of the different G4 models PowerBook G4 Specs carefully review the ports as there are a few different layouts, you need to match like for like. Also note the graphics in this series used an ATI (AMD) Mobility Radeon chip which also offered the needed I/O interface. You just have different generations.
由 DanJ 完成的
@puttkitsu just to clarify, you want to replace your faulty 820-1615 board with a 820-1688 board?
It will help if you can specify your exact model number.
由 oldturkey03 完成的
