iPhone 4 and 4s battery the same?
Can I use an iPhone 4 battery in an iPhone 4s ?
Thanks!
Unfortunately the simple answer is no. The iPhones 4's battery has a different voltage and the connector is slightly different. If you need a new battery you can get one from here,
that will work no problem in your phone.
Hope this helps.
这个答案有帮助吗?
voltage is the same at 3.7. 4s batt has tiny more watt hrs. make it fit by modify connector tab only.
The voltage is the same. They are both 3.7 volt batteries. However the 4s battery has a very slightly higher capacity.
Owen Cunneely youre wrong sir
Batteries are different physical size as well. The 4 is bigger than the 4s. Normally the 4s will fit in the 4, but not vice-versa.
这个答案有帮助吗?
Very helpful ta very much. Ytnir.
if i need a battery for an iphone 4, will the 4s battery work?
I think the 4S fits in the 4, yes, but this is a terribly late answer to your question :-)
这个答案有帮助吗?
if voltage is the same can you switch between the batteries?
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 66
总计 148,542
4条评论
can i use an i phone 4s battery on an iphone 4
由 sudha 完成的
Can I use a 4g battery in a 4 s
由 John 完成的
can i use iphone 4s battery for iphone 4
由 Rekha Gore 完成的
Yes you can use it..but fix the connecter in opposite side...I am using...
由 nilimesh15ganapati 完成的
