phone switch off not starting
not able to start the phone when connecting to charger only red light comes but does not starts
If you see a red light when connecting your phone to the charger but it doesn’t start up, it suggests that the phone is receiving power, but it might not be able to boot up properly.
If the phone has a hardware issue with the battery or the internal power supply, it could cause the phone to not start even when charging. The red light may be an indicator of this issue.
In this case, charge for at least 30 minutes to an hour before attempting to power it on. Sometimes, if the battery is deeply drained, it might take a while for the phone to show any signs of life. Ensure you're using a reliable charger.
这个答案有帮助吗?
i charged the phone and also i removed the battery and added new battery to it but than also not starting what will be the issue in hardware i am technical guy would you recommend me the schedule
additionally i remove the battery and i connect the charger without battery also than also red light was coming but the phone was not starting
@rahulyadav37502 If the light stays on even with the battery in and no boot, the issue might not be the battery itself. A failed motherboard, damaged power button, or blown fuse (common in older phones after battery issues) could be at play.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 127
