跳转到主内容
加入维修社区 - 创建账户
Is there a way to repair the WD Green SSD as it is not being detected?
My SSD is not being deducted, but in the same port I use other SSD and it is working fine. Could you suggest a way to repair it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
What is your system? Over the years the SATA port has been upgraded from the original SATA I (1.5 Gbps) to SATA II (3.0 Gbps) and the current SATA III (6.0 Gbps). So depending on the age of your system you maybe trying to use a SSD which can’t run with it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sri manoj 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 73
总计 1,247
