NDS lite resets itself constantly
My NDS turns on and works fine for anywhere between a few seconds and a couple of minutes. Then it resets and the same thing happens again.
Don't think it's a battery issue as I have bought a fresh battery.
Any ideas what might be causing this issue?
Hi @bobby19222
Does it stay on if you use it with the charger connected?
由 jayeff 完成的
Hi @jayeff thanks for the reply! I just checked there and no, the same thing happens. Also it happens whether or not a game is inserted (and no matter which game).
由 Bobby 完成的
@bobby19222
Seems like a loose connection somewhere.
Check that all the flex cables in the device are securely connected and not loose.
Here's the Nintendo DS Lite repair guide that may help.
由 jayeff 完成的
