Why my PC is turned on and not displaying in monitor it just making
It just making a loud fan noise please help me
HP Compaq 8200 Elite 是一款小型工作站级台式电脑,面向高端办公和设计工作。它的设计相当易于维修,重点在于让技术人员能够快速更换驱动器和板卡。
more symptoms are needed - like are your LEDs doing anything.
Based on just the fan noise - I would say it is running at full speed because the temp sensor is telling it it is hot. That might indicate the CPU is shorted out.
I had that problem on one of my laptops.
Possible corrupted BIOS setting(s) preventing normal operation and startup perhaps.
Try a power refresh and check if that resolves the problem:
Here's the maintenance and service guide for the PC. Go to p.241 (253 of 345 pdf) to view the procedure to remove the battery from the board. If the battery is >4-5 years old, replace it. The battery model number can be found on the battery itself e.g. CR2032 etc
If the PC does start OK, then there may be a message stating that the dat and time are incorrect. This is normal as the BIOS has been rest back to its default factory settings. Once the data and time have been corrected, the message won't appear the next time the PC is started. Also any user definable settings in BIOS that were changed by you to suit whatever system requirements you needed, will have to be changed back again as well.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 200
