跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
问题已关闭
[AT&T] Will Opening iPhone 4s back housing will Void my Warranty?
Hi
I have a question
if i replace my housing with my custom iphone 4s housing one. Will it void the warranty? I mean like if i change it back to original before i sent it to them to get something fix will it work? Is there a indicator to check if i have open the iphone before?
Thank you!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Oficially if you make ANY changes to your iPhone it will void your waranty.
BUT if you only change the back of the iphone 4 and change it back to the original one if you need to send it for warranty there is no way to see or detect that is had been removed. There is no indicator for this.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,378
