跳转到主内容
加入维修社区 - 创建账户
作为广受欢迎的 Samsung WB150F 的继任者,WB250F 强调了通过 Samsung 的 Direct Link 和 Smart Camera App 实现的共享功能。
Screen won’t turn on
my camera can turn on as normal and even the touchscreen works but the screen stays black.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@john81163 if there is no menu showing or anything then it is most likely the LCD screen itself. It is possible that this is a backlight issue, so darken the room and turn the camera on. Now use a flashlight and angle the light at the screen on different areas. See if you can make out the cameras menu. If you do, then it is possible that this is a bad backlight . If not, I would proceed to replace the screen.
Since iFixit doesn't yet have a guide for this, use something like this video or even this one for the replacement.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 255
