跳转到主内容
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
DSi "The device inserted in the SD Card Slot can't be used."
As the title describes, the DSI unit I'm working on isn't able to read SD cards, displaying the following error when trying to access them via the Camera app. Here's what I've done so far:
  • Replaced L/R/SD card flex cable with new cable.
  • Swapped DSI backplate (with flex cable) with a known working system.
  • Tried several SD cards, re-formatted both with the standard file explorer and the official SD card formatter. Can confirm full function with known working DSI.
At this point I'm almost certain it's a motherboard problem. Based on the rust in the system, (none on the flex cable contacts, mainly on the game cart reader) I'm willing to bet it's suffered water damage and now the motherboard can't read SD cards at all.
At this point I would just go ahead and perform a motherboard swap, but my client specifically wants this board fixed to get their childhood photos off the unit. As far as I know, the SD card is the only way to go about doing that, right?
Two questions:
  1. Is there any chance I could fix this problem on the motherboard?
  2. If not, can I get the photos off the device in any other way?
Update (02/12/25)
So I'm throwing in the towel on fixing the problem, but on a good note I figured out a different (albeit slow) way to get the photos off the unit. You can exchange photos over wireless within the camera app if you have another DSi. What I ended up doing was transferring all the photos from the broken unit via this method to an SD card in another working unit. I then transferred the files off the SD card to my client.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Ah thanks for letting us know!! It's great to know that there is another possibility to get the photo's from the DSi!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi there!
Yeah, sound like a motherboard issue. I agree.
I don’t think it’s possible to get the photo’s off the DSi without SD card :(.
So it’s worth the try to get the motherboard fixed! First you need the schematic to see what is responsible for this.
You can follow this (I know it’s for the XL, but the IC’s do look near the same): Nintendo DSi XL Teardown
Scroll all down to see the IC’s explained. The IC which is responsible for the I/O or SD card slot is none of them. So it is something else, sorry.
What you can try is to clean everything, maybe doing a reflow carefully? It’s difficult to tell which component is responsible for the SD card reader.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
SelectStartRepairs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 38
总计 382
