跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 是任天堂发布的第七代掌上游戏机,是继折叠款 Game & Watch 之后,又一款双屏掌上游戏机。
Why does the power light turn green then orange then shut off?
I am currently fixing an old Nintendo DS. I had put in a battery and by the fact that the bottom screen flashed but the top didn't, I replaced the top screen ribbon. However, when I closed up the new shell (old one was destroyed) and put in the battery to try and power it, it didn't turn on at all other than the power going green, then turning orange then shutting off. Unlike before, the screen doesn't even flash. Any ideas as to what may be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi there!
This is strange. Did you double checked if everything is connected properly? How are the battery pins? Could you share some pictures with us regarding the motherboard? It’s most likely motherboard related..
这个答案有帮助吗?
得分 1
2条评论:
I have added pics to the post. If you'd like any more specific photos please let me know.
完成的
Thanks for the pictures! Everything is connected as it should be and can’t see any component that physically failed. Please check the fuses (labeled with F) with a continuity test. Also check the EM10 labeled on the motherboard. If all of them are fine, it’s easier to get a new motherboard… sorry.
完成的
添加一条评论
Try this.
Orange LED turns on for 5 seconds then shuts off when plugged in
这个答案有帮助吗?
得分 0
2条评论:
I tried it and unfortunately it still didn't work
完成的
When I tried holding the power as I plugged it in, not did the orange light flash, there was at the same time a great light that flashes as well
完成的
添加一条评论
添加你的答案
Nathan Cote 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 118
