跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
DSi blue light flashes and nothing else happens
I have a dsi that the blue light will flash when I press the power button. The top and bottom screen kinda turn a different shade of black for a split second, but nothing else happens. I have tried:
new battery
new daughter board
replaced both screens
cleaned all cable connectors
checked for water damage
soft reset/ hard reset in case of missed update
Replaced the wifi board
I even removed the motherboard and placed it into a known working DSi, but it still had the same issue. The mother DSi is my brother's and has been very well kept. It has no cosmetic or physical damage at all. What would I be looking at as possible reasons it doesn't work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Owen!
It sounds like you’ve tried everything! So it must be motherboard related. The easiest thing to do, is to replace the motherboard.
You can buy them here:
https://a.aliexpress.com/_EyQsNCY
They are not that expensive anymore, so it’s worth the try!
这个答案有帮助吗?
得分 1
2条评论:
I was hoping to fix the motherboard. It has downloaded the games we played. Before I replace the board, I will try to replace the digitizer ribbon cable connector. I heard that may be the issue.
完成的
Ahh, I see. Yes, you can try that first. Please also double check all the ribbon cables to see if they are connected properly.
完成的
添加一条评论
添加你的答案
Owen Lee Snook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 408
