跳转到主内容
加入维修社区 - 创建账户
Wii Remote 是任天堂于 2006 年 11 月 19 日发布的游戏主机 Wii 的原始主控制器。初代 Wii Remote 的型号为 RVL-003。
Battery leak on contacts and motherboard
https://amzn.in/d/2XzswFN
Is this okay for use on motherboard??
Also can it damage the plastic or foam pieces if accidentally spilled?
I am new to repairing stuff like this so help will be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
Yes, the product in the link is perfect to use! Be aware, that traces could be damaged and other components could be broken by the acid.
First, de-solder the battery pins on the motherboard and clean it completely. Then check for damage (if you can share pictures with us, that would be great).
Replace broken components and repair traces if needed, then solder some new battery pins in. Also make sure to replace the battery pins inside the shell. Then test if it's working again or not.
This is the only way to completely fix the Wii Remote :)!
If you have any questions, feel free to ask!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aeron Brar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 716
