跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
My USB ports aren't working after installing MacOS Sonoma
I recently acquired a imac Intel computer through a bidding on abandoned storage unit. Anyways when I got her home cleaned up and turned on It was outdated and not updating with the current MacOS operating system. I ended up using an external hard drive to update it to the Sonoma version. Everything was great and then it had an update through apple's automatic software updates.
Now my USB ports just stopped working, and now I can't do anything after I turn it on. I can't type anything. I can't click on anything to get into it. I did read somewhere online that the newer Mac computers don't have USB ports in favor of Bluetooth and wireless connections, so that could have something to do with it, but I need those to revert back to the older macOS version just so I can get all my programs and pictures off of it and figure out how to go from there as far as updating it goes.
Any information you can provide would be great. I'm not super tech-savvy when it comes to Apple products, so please baby steps with me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hey there OP, can you help us to identify your iMac? This will give us a better idea of how we can help you out.
完成的
OF COURSE!
Slight oversite on not providing the most important information 😆
IMAC 24"/ 2.66 GHZ/2X2GB/MODEL A1225/ IC4324A/BRCM1022/MAC OS VERSION 12.7.6
完成的
Did you use OpenCore to update it?
完成的
Yes I did...
完成的
添加一条评论
2个答案
doy you try this?
# System Settings->Privacy&Security->Allow accessories to connect->Ask every time
# Turn off machine
# Reboot
At this point I got a popup asking if I agreed to the assessory and I answered yes.
这个答案有帮助吗?
得分 0
添加一条评论
So OpenCore has a known issue with USB 1.1. The core of it is that Apple dropped all support for USB 1.1, and as you've experienced, it affects any pre-2009 Mac attempting to run anything past macOS 13. From what I could find, the only workaround for this issue is to buy a USB 2.0 hub and connect an external mouse and keyboard to install macOS. This should allow you to eventually run root patching.
这个答案有帮助吗?
得分 0
2条评论:
Any recommendations for a usb 2.0 hub?
完成的
@tylorthetailor Amazon Basic has one that has 7 ports if you're planning on using anything else. Otherwise if you're just looking for keyboard and mouse Plugable has one that should work fine.
完成的
添加一条评论
添加你的答案
Tylor Leigh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 322
